NEED HELP ASAP GS300 with 20' setup.
hey i have a 98 gs300 im going to buy some 20" rims they coming off an lexus ISF they are 20x8.5 in front 245/35/20 and rear is 20x10 245/35/20
off set is +30 on the rear which is 20x10 and +38 in the front which is 20x8.5 now if i roll my fenders im going to be lowering the car 1.5 in front and 1.0 in rear will the rims still rub ? or will i still have a good ride?? please let me know asap thanks
Based on the tire size this is a fat set-up so you shouldn't have to cut/pull/roll, etc. The big questions is, what are the off-sets (front/rear)?
If you're going from stock 16's to 20's your ride will suffer. There's no way of escaping it plus sizing that significantly.
You should be fine. The tire size and offsets you got aren't aggressive at all. And with that mild of a drop, you'll RARELY rub if ever. I've got 20's with similar offsets and same tires. The only time I rub is in the front going into driveways or something too quickly. And I'm dropped 2.5" in the front.
AJ STYLEZ
GS - 1st Gen (1993-1997)
14
11-15-10 09:53 PM
