Coilover question
Old 03-11-11, 07:20 PM
nvryder
nvryder's Avatar
sweet thanks....
Old 03-21-11, 06:02 PM
LIs300
LIs300's Avatar
stance coilovers are really good u should check those out
Old 03-23-11, 11:52 AM
pl91741
pl91741's Avatar
Circuit Sports DPS COilover!!!
Old 03-23-11, 11:53 AM
pl91741
pl91741's Avatar
BTW... what links do you guys run on Is??
Old 07-08-11, 11:31 AM
Remy08
Remy08's Avatar
Has anyone ran the tein flex or heard anything on the tein flex's? Im looking for a low stance but want to run the edfc as well. Thanks aheard of time for the help
Old 08-05-11, 02:25 PM
itr206
itr206's Avatar
I ran them on my Supra. I loved them. Best part of these are that the preload of the springs are independant of ride height, which is not something you usually find on a cheaper coilover.
(IE- as the car gets lower, the spring tension may change and cause stiffer ride)
Old 09-11-11, 01:23 AM
nvryder
nvryder's Avatar
Update...I ended up getting the megan coilover set up. Overall, I am satisfied but I after about 4 months I am starting to get a chattering noise from the driver front. It only happens when I hit small bumps in the road or the road reflectors while changing lanes. I don't think its the lock nut as I tightened it to make sure it was not loose. Any thoughts?
Old 09-11-11, 06:28 AM
SuthrnGent
SuthrnGent's Avatar
edit: NVM didn't read the lock nut part
Old 02-19-13, 04:57 PM
LowLifeSXE
LowLifeSXE's Avatar
Powered By Max! Best coils ever super low super stiff
ArmyofOne
09-10-17 11:04 AM
jromero385
Suspension and Brakes
01-28-11 12:23 PM
UpperCase
01-11-08 04:55 PM
akkord
06-21-06 09:54 PM
LegSC300
09-15-03 02:55 AM
Quick Reply: Coilover question
