Megan EZ Street or Street LP Coils?
I was originally looking at the F-sport springs for a mild drop that will maintain a close to stock ride but the more Im looking around, I think coilovers are better suited for my needs. I want to be able to raise and lower for winter and also like the idea of adjusting the damping to exactly how I want it to ride. That being said, which coilover would have a more stock-like and comfortable ride?
why would the ez ride better....? on the site the spring rate is the same and the lp is the luxury line for the smooth ride??? not understanding, and i just bought the LP because i wanted the smooth ride....
on there site they are both 10/8... dunno.... i have LP and they ride great. both will be good
http://www.meganracing.com/product_d...id=30&catid=30
Megan LP http://www.meganracing.com/product_d...d=401&catid=30
Megan EZ http://www.meganracing.com/product_d...=1055&catid=86
Hopefully a guru will chime in, but how I understand it is that the lower you want drop your car the higher the spring rate you want so there isnt much suspension travel (keep you from rubbing) and wont bottom out. Youll also be able to keep the damping setting a little bit softer. Some guys will slam their car on coilovers with a lower spring rate, so to keep from rubbing they have to keep there damper setting almost completely maxed out stiff. From what I understand this will wear out the shock faster.
Youll definatly want to know how low you plan on dropping your car before buying a set of coilovers. If you plan on slamming your car with aggressive offsets youll probably be better off getting something like the LP (12k/8k) or BC racing with custom spring rates.
