Steering vibration turning wheel left VIDEO
Old 03-05-11, 09:24 PM
ISFFUN
ISFFUN's Avatar
Default Steering vibration turning wheel left VIDEO
Anyone got any ideas?
New steering rack bushings, new control arm bushings, new sway bar end links, car just aligned. No fix.
Inthe video I turn it left and come back half way twice, then I go all the way to the right and back again. The last part of the clip is with the window down but you can't really hear it.
http://www.youtube.com/watch?v=fWEkLUPAolc
Old 03-06-11, 10:52 AM
MidloSC
MidloSC's Avatar
Steering rack itself or a weak pump?
Old 03-06-11, 10:58 AM
Luxor
Luxor's Avatar
Is it similar to this?
https://www.clublexus.com/forums/sus...ped-video.html
Old 03-06-11, 11:24 AM
ISFFUN
ISFFUN's Avatar
Luxor I believe so! You can actually see the wheel jiggle if you look close enough. It's REALLY obvious when the car is on an incline (like, parked where your front end is higher than the back)
Did you have any luck fixing it? Are your sway bar end links original?
Old 03-06-11, 12:21 PM
Luxor
Luxor's Avatar
I could never figure out what caused the studder. My end links are original. But my lower control arm (urethane)bushings and steering rack (urethane)bushings have been replaced a while ago.
I started getting this problem when I replaced my steering rack with a new one.
But it seemed to stop doing it couple months after I posted that video. I haven't noticed it studder in a while, so I guess it fixed itself.
Old 03-06-11, 02:59 PM
Luxor
Luxor's Avatar
I take that back. I just tried it again and it still does it, but not as bad as it used to. I guess I got used to it, but I hope there is a fix for it!
Old 03-06-11, 04:19 PM
k7q
k7q's Avatar
try to put the car in park and give it some gas and turn the wheel to the left and see if it still does the same thing.
Old 03-06-11, 07:47 PM
ISFFUN
ISFFUN's Avatar
No luck with revving it up to 2,000RPM and turning the wheel left and right. Same thing.
Old 03-06-11, 11:39 PM
Str8sikk
Str8sikk's Avatar
steering rack....you said it yourself it did it after you installed a new rack.. its defective
Old 03-07-11, 07:36 AM
ISFFUN
ISFFUN's Avatar
Interesting - at 5AM (45 F outside) I started it up and turned it left and right and the vibration was gone. As soon as I drove it about a mile and made a few turns it started doing it again.
Old 03-07-11, 09:40 AM
BattleVer
BattleVer's Avatar
check your fluid level, if theres air bubbles that will happen.
Old 03-07-11, 10:50 AM
ISFFUN
ISFFUN's Avatar
Fluid is full I'll just flush and bleed it. It's been at least 2 years.
Old 03-09-11, 08:52 AM
ScJz
ScJz's Avatar
I was going to say fluid level aswell
Old 03-19-11, 06:45 PM
xspsi6
xspsi6's Avatar
Mine does this as well but I have not looked in to it yet.
Old 04-14-11, 06:38 AM
portion
portion's Avatar
any fix for this problem? it started happening recently.
Moarpower
12-17-18 09:26 AM
mulcryant
SC- 1st Gen (1992-2000)
06-09-14 12:15 PM
MIGS
Performance & Maintenance
12
11-14-10 06:25 PM
Luxor
Suspension and Brakes
05-20-10 12:27 AM
Dslexic
02-20-09 03:03 PM
Quick Reply: Steering vibration turning wheel left VIDEO
