I've heard of people talking about using these bushings, but no solid info if they work 100%. Can you confirm that they fit? If so im jumping on a set of these, screw TME....
As soon as install them i'll let you know ,but everyone I spoke with especially MVP said they are a direct replacement with no problems whatsoever.
The round bushings with the metal sleeve worked great as expected, but the other bigger bushing that goes under the metal bracket DID NOT WORK. Its too narrow by about 4MM to fit under that metal band/bracket on my car. The diameter of the bushing was fine, just the width was too narrow.
I'm currently looking into trying to get my hands on a Supra metal bracket to see the differences.
Just wanted to give a heads up on that.
ALSO... I wouldn't order from a company I couldnt TALK to a human being at easily. I've called MVP with an issue before, and they handled it immediately on the phone. Not bad mouthing TME, but seriously if you have to chase a supplier down they can suckit.
