Question about Rear sway install...
when installing the rear aftermarket sway bars... whats the right way to position the rear endlink?? ive read some crazy tricks to install it but im not sure whats right or wrong..
i have Intrax Sways. (installed in my car currently and just making sure)
Thanks
Thanks
Position the end link in a way that it's not angled too much. I know when I had my Daizens, I had to reverse the link's position otherwise it would angle at 45 degress or some odd number. I don't know much about the Intrax sways, but you could just flip one of them and see which orientation looks more suitable.
There is a definitive answer.
It should have come with the installation instructions on the sways.
The daizen's instruction sheets specifically say to flip the endlinks as part of the install.
So it depends if the Intrax sways are designed the same dimensions as the OEM or was designed larger to flip the endlinks like the daizens
02Ku
09-16-07 10:14 PM
