Slight Vibration at idle after BC Coil install
Probably from the use of the top plates since there metal with no sort of rubber bushing like the stock units. This will help with road feedback but you probably will feel more vibration because of this.
Alignment should not have anything to do with this but you do need to get it aligned asap since i'm sure your toe and camber are off.
Sorry if this is a dumb question, but i've never seen the tops of the stock units.
Metal on metal could be the culprit.
Cannot reuse the stock tops. Its very likely you will get vibration because of the metal tops. I do actually think BC sells rubber bushings that can be used with there top hats. I'm not 100% on this but I thought they did.
lexasgs400
09-10-10 12:01 PM
Sarorn
Suspension and Brakes
02-20-10 01:57 PM
