still no camber kit available for front on IS350's
Its been a while since Ive been on here, and I cant believe there is no front camber kit available for the IS350, WOW! ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Has anyone heard of anything in the works lately??
The IS300 spc ball joints are the only solution around so far. You have to modify the joints a little bit but you can get a good +/- 1 camber for the fronts. A lot of shops don't like dealing with them because ball joints can shift when you're trying to adjust the camber.
Tech Info Resource
Tech Info Resource
They're all the same, 2IS and 3GS have the same front components. Not adjustable from the factory because it's cheaper for them to build cars this way.
