suspension noises
#31
Ive had my coilovers for about 3 months now and i recently got the "clunk". It is coming from the front right corner/tire and its only noticable when im on harshish roads. Im on Megan EZ coilovers and their was no clunk when I first installed them, only after i got low and whatnot. wondering if ANYONE has found a definitive solution to the clunk yet???
#32
Yeah I finally figured out my issue with my clunkking with the Megans.One of two things it's time for you to get new arm bushings(which is the more squeaking sound)or like TechGeek said your riding on your shocks instead of your springs so adjust the bottom collars up a little so there is more tension on the spring.The springs may look stiff and all but,with my Megans I have already had to tighten the collars up 3x times now cause they slowly loosen on it's own from all the road vibration.Nothing to worry about![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#33
This is known as the "preload" correct? From my understanding their is suppose to be some play in the spring, about 1mm? I thought this was causeing it so i did adjust up the top two collars so their was a little preload but im still getting the noise. Should i move them up further? I mean their not too preloaded as of now.
#36
There should be zero play in the spring. Adjust it as tight as it will go without changing the height of the spring ( should be the same height as it is unloaded completely).
Preload will cause major issues if you're not tuning suspension for it at the track and start hitting bumps on the street. Play in the spring will cause major ride quality issues and kill the shock <ever heard a 3500 lb car land on the side of the bottom of the coil then reseat it self? Louddddd pops>.
http://www.meganracing.com/tech/inst...5&subject=CDK:
Read it ten times. Alignment and preload needs to be set after ride height changes. Set your ride height then double check spring height.
#37
So i began to reset the spring on the wheel thats making the noise, and i notice i had ALOT of preset. So i obviously was riding on springs even tho the ride was not very harsh. i reset it and then tightened all the springs to the point where they would not constrict, but were tight and i was not able to move/twist them at all. Ill report back when i take it for a test run
#38
#39
The spring height when tightened should be the exact same as it is unloaded. Zero Preload. You've got your springs compressed right now so you're riding on less shock travel and are super heating the oils inside of them.
You need to have it at 8 inches if that's the same with the spring off the assembly.
The center stop nut should be torqued to spec as well as the four tower nuts and the bottom. There should be zero movement in the assembly in terms of the overall structure.
#40
have you noticed that everyone has the same problem with ls4oo front end ! I love my LS400 but have spent all the money and time trying to find this noise ! I've decided to drive it until it breaks then I will know what it was. I've taken it to several shops, replaced several parts, still getting that sound. I give up, love the car but Lexus blew it big time in this area !!!! good luck PS: sound is getting worse so hope to find out soon ! Lol
#42
Im about to just dip the whole coilover in some wd40... its been 2 weeks and ive adjusted the coilovers about 5-6 times making sure everything is correct. 0 preload, no vertical play, i can spin the spring with force, everythhing tightened to oem torque specs, and all i hear in the front is CLUNK CLUNK CLUNK when going over bumpy roads. The coils still have less than 500 miles and the noises started after about 100 miles on them. maybe in that 100 miles something went bad?
