Short Review: Brembo Blanks+Akebono ProACT Pads
Old 04-08-11, 07:08 AM
Quick VR-4
Quick VR-4's Avatar
Default Short Review: Brembo Blanks+Akebono ProACT Pads
Well, I was starting to get a slight wobble with my factory brakes and decided it was time to get my rotors turned and new pads. Then I found a great deal on some Brembo blanks (thanks timgs300) and read some positive reviews on Akebono ProACT ceramic pads. I could not be happier with the results of this combination and seem much better than what the previous set up was (not sure what as prior owner probably had new brakes installed through Lexus dealer). I do not have any specific data, but I would say braking has improved approximately 20%.
I also had the wobble at 60 mph and decided with the new set-up to remove any rust from the hub of the rotor and my wheels. I sprayed a light coat of Rustoleum on the rotor hub to prevent rust and now my wobble has completely disappered.
If anyone is looking for moderate braking improvement without spending big money, this was a great upgrade for less than $200.
Old 04-08-11, 10:21 AM
raytseng
raytseng's Avatar
I have the same, except i have the centric premium blanks instead (maybe cheaper than brembo-check tirerack/rockauto but look completely just as good if not better than the brembo)
I also had the shop also change out the brake fluid at the same time.
Per Akebono, I didn't do any bed-in procedures but just drove normally and braked moderately. Took a couple hundred miles for the surfaces to mate, during which you hear whirring from the rotor's grind pattern, but now they grip pretty well...
Old 04-08-11, 12:36 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Nice! It is a nice oem brake setup. I too have Akebono ProAct ceramics with the Brembo X-drilled rotors.
Old 04-13-11, 05:59 PM
ALowGS
ALowGS's Avatar
Was the 200 for just the fronts? Where were these purchased from?
Old 04-14-11, 08:34 AM
Quick VR-4
Quick VR-4's Avatar
That was for everything including rotors. Tire Rack has the pads on sale right now. Fronts are $56 and rears are $51.
http://www.tirerack.com/brakes/resul...1&autoModClar=
Old 04-14-11, 10:58 AM
raytseng
raytseng's Avatar
if you're looking to buy, also check out rockauto's prices. you should also be able to search around to get a 5% coupon to there...
Old 10-23-11, 10:55 AM
gtmax
gtmax's Avatar
Im going to go with you dudes recommendation and do brembo rotors/Akebono pads, though only for the rear since that's what i need. I hope it turns out good and i'd like to hear more feedback from you guys as to how they are holding up.
'99 GS400 here.
Old 10-24-11, 08:56 AM
Quick VR-4
Quick VR-4's Avatar
It has not been too long since my first post, but my set-up is still performing flawlessly.
Old 10-25-11, 03:52 PM
gtmax
gtmax's Avatar
Mines are coming in the mail tomorrow. Gotta get them installed right away since my rear breaks have been as squeaky as a JAV star.
Old 10-27-11, 08:47 PM
greene
greene's Avatar
Nice. I have the brake performance drilled / slotted rotors, ss/lines, with Akebono pads. Did the bed in and the peddal feel is alot better, and stops alot shorter.
Old 05-03-12, 12:58 PM
4eign
4eign's Avatar
bumping this for a question. greene, how did u bed in the pads?
cschmatz
12-20-21 09:09 AM
deeken
GX - 1st Gen (2003-2009)
07-14-18 05:35 AM
mdorn98
06-02-15 06:48 AM
jubay
05-01-14 09:24 AM
gsowner88
GS - 1st Gen (1993-1997)
10-01-07 04:56 PM
Quick Reply: Short Review: Brembo Blanks+Akebono ProACT Pads
