Coils questions
Coils questions
1. BC coils out of the box installed without messing with ride height. Will I be able to use the jack stand that came with the car to jack it up? Or will it be to low?
2. Measuring side to side is easy with just measuring the distance between the lower ring and the upper. But how do you measure height from front to rear to make sure its even?
You should be able to use your jack. One thing you can do is when you take out stocks, make the coilovers the same height or a bit lower and it should be fine.
To even out front to back, measure ground to top of fender arch. That's what I have been using.
pieisgude
Suspension and Brakes
17
09-09-14 10:22 AM
