Steering wheel shakes when I brake...
Old 04-13-11, 11:49 AM
Got0wned
Got0wned's Avatar
Default Steering wheel shakes when I brake...
Steering wheel shakes when I brake... What can it be?
Old 04-13-11, 11:53 AM
Lexusfam
Lexusfam's Avatar
Warped rotors. Should feel it in the brake pedal too, if you don't feel it in the brake pedal,its something else.
Old 04-13-11, 11:59 AM
DubK250
DubK250's Avatar
Only when you brake? Or also when you get off the gas pedal (less pronounced shake) at like 70mph?
Old 04-13-11, 01:40 PM
billzblaze
billzblaze's Avatar
Mine used to do that also but i changed the brake pads and had the rotors turned and it
fixed the problem so check the pads also
Old 04-13-11, 03:46 PM
pinoiryder
pinoiryder's Avatar
looks like warp rotors.. check you rotors and brake pads.
Old 04-13-11, 03:53 PM
GS671
GS671's Avatar
Yup like what all the above posts say, It's most likely your brake rotors and pads
Old 04-18-11, 08:29 AM
Got0wned
Got0wned's Avatar
thanks for everyone's input. I'll check the rotors when I get the chance. Could wheel bearings also be a possibility? I recently put on 18x9 and 18x10 wheels from stock wheels and the shaking got worse. I now feel the shaking when going on the freeway even when I'm not braking. I did an alignment two weeks back as well
Old 04-18-11, 01:07 PM
DRELOC
DRELOC's Avatar
^^^ I would like to know this also as i have the same issues recently after installing larger wheels
Old 04-18-11, 01:34 PM
fuzzzz
fuzzzz's Avatar
balance your wheels, tire pressure?
Old 04-18-11, 02:41 PM
AW99GS400
AW99GS400's Avatar
steering wheel shakes at highway speed when try to slow down = warped rotors
steering wheel shakes when install larger rims = centric ring most likely
Old 04-18-11, 06:00 PM
McKrevice
McKrevice's Avatar
Do not rule out tie rods.
Old 04-18-11, 06:34 PM
GSRSRT
GSRSRT's Avatar
thank god for this post!! ok so i have this same problem so here it go's i just installed brand new shocks, upper control arms and steering rack bushings so i thought now im good! yeaa right now i keep hearing a humming noise when i go over 40 mph which causes the steering wheel to violently hake and it shakes bad i also installed New break pads with all the hardware so i went and put the car on a lift and guess what the left front wheel feels like its locked!!! idk what this can be but the Bearing!! so my questions is, Is this problem the Bearing and if it is how much will a spindle cost me from Lexus because rockauto.com does not carry this item.
Old 04-18-11, 08:55 PM
McKrevice
McKrevice's Avatar
what do you mean it feels like it's locked? Like the caliper won't release from the rotor?
And if it's the wheel bearing, it does not appear that the bearing and spindle are one piece. I would imagine that you can take your spindle off and press out the bearing and press in new ones if that's the problem.
Old 04-18-11, 09:03 PM
99 GS3
99 GS3's Avatar
No need to replace the spindle, you can just get bearings from lots of places, including rockauto. They are right on rockauto's site listed for like $4x.xx or so.. Check Carson Toyota or Swell Lexus if you want oem bearings.
Old 04-18-11, 09:56 PM
GSRSRT
GSRSRT's Avatar
but don't you need a press!! to take em off which i don't own one
Quick Reply: Steering wheel shakes when I brake...
