Installed FIGS rear tie rod end links
negative. I took extra precaution when removing the arm. I made sure i didnt drop anything on the line to damage it. Most likely you tugged the wire by accident which caused the sensor/wire to damage.
run a abs sensor check thing (like a OBDII reader) and see which side it is and just replace it or fix it
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I want RCA Histeer!!!
i think i will be later on haha. ide like to have them Teal like my front brakes.
that is.. i get all FIG stuff haha
btw my rear toe arm got scratched up from a money wrench that Firestone guy used
idiot doesnt realize that hose was there to use..
i think figs shoulda had them middle section cut out so you can use a wrench...
