Installed FIGS rear tie rod end links
Got them installed today and I'm stoked that my rear Total Toe is .1! Before with the OEM links it was like 1.23. Even the alignment guy was amazed. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
After installing the links, now my ABS light is on.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Anyone got this problem? I was very careful with the ABS wires.
UPDT?
its possible the abs sensor wire was strained, but its a magnetic pickup and should be able to be fixed if careful.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
