crackling sound when i ride the brakes?!?
Old 05-01-11, 07:14 AM
meangene
meangene's Avatar
I'm using all oem parts, no aftermarket and i get that noise. I still haven't had the time to get under there and take a look. Hopefully I can do it next weekend.
Old 05-05-11, 12:48 PM
greg0723
greg0723's Avatar
cool let me know if you find anything out. is there a possiblity the pads are in backwards or anything? probably a dumb question lol.
Old 05-06-11, 11:59 AM
hung8852
hung8852's Avatar
I wish that was the case!! i couldve fixed it by now!! ..i hope i have time this weekend to take a look at it again..
Old 05-21-11, 07:01 PM
hung8852
hung8852's Avatar
im fed up with the sound..i bought a new set of oem brakes with shim kit and fitting kit...
good God, let this be the solution to this!!!
Old 05-22-11, 01:21 AM
hazmat
hazmat's Avatar
I have the exact same sound, went to the dealer and they replace the oem rotors and pads and shims everything. I got the extended warranty and even though it has about less than 20k miles on it and there are plenty of pads and rotors. Sounds gone for now and that's 2 months ago
Old 05-22-11, 02:56 PM
1badlex
1badlex's Avatar
Same problem I already replaced the rotors and pads n noise is still here, guess I'll change out the shims n grease up everything next
Old 06-12-11, 02:52 PM
greg0723
greg0723's Avatar
hey hung did it work out for you?
Old 06-13-11, 03:03 PM
hung8852
hung8852's Avatar
I havent had the chance to install the new brakes yet. been raining the last weekend and out of town the weekend before. i should be able to do it this coming weekend. hopefully its the shims.
Old 06-15-11, 01:40 AM
greg0723
greg0723's Avatar
i just ordered some factory brake pads and shims form sewell. i hope this works replacing my aftermarket ones.
Old 06-16-11, 05:10 PM
Gville350
Gville350's Avatar
So do the OEM pads from the factory come with shims? Those you that pulled them to look, are they still in good shape?
Old 06-16-11, 05:59 PM
greg0723
greg0723's Avatar
i ordered mine from sewell. front brake pads were $47 and front shims were $33
Old 06-18-11, 08:26 PM
hung8852
hung8852's Avatar
i finally had the chance to put in the new brake and shims!! and thank the lord, it worked!! the sound stopped , braking feels smoother too! i cleaned out wverything with brake cleaners. i did thoroughly clean out the inside of the caliper too, that might have helped. never again will i buy posi-quiet brake pads!! sadly theres still allota meat left on it too. what a waste... at least i fixed the sound !!
Old 06-19-11, 08:29 AM
Gville350
Gville350's Avatar
^Great to hear! I just got cleaned up from checking out my driver's front brakes. Not sure how long normal OEM brakes are supposed to last but the inner pad is almost gone!!! The outer pad looks to have normal wear for 34k. So yeah, I assume the noises I've been is done to the "idiot pin" scratching against the rotor. LOL!
Time for new pads and rotors for me!
Old 06-19-11, 03:17 PM
hung8852
hung8852's Avatar
34k!? thats awesome for the OEM brake pads.. im at 54k miles already and changed it twice. well third time, but i went cheap and got posi-quiet crap, ended up changing it ..
hope people with the same problem sees this. just need to clean out the pistons thoroughly and get new shims!! grease it properly!!
Old 06-20-11, 11:45 AM
Gville350
Gville350's Avatar
LOL! Ok, so I ordered Power Slots slotted rotors and Axxis Ultimates. I figure, if I can put up with the amount of dust these pads produce why not get a performance pad and get the best and the worst.
Hoping that my items arrive by next weekend so I can do the brake job.
Quick Reply: crackling sound when i ride the brakes?!?
