IS300 Front Camber A-Arm Compatible
i just read through 6 pages of the Megan rear camber arm and SPC balljoint from the IS300 thread, saw this post but no one else seems to give anymore detail on it
was wondering if getting the Hardrace Camber A arms from the IS300 would work on my ISx50, I'm actually leaning towards this route since it seems less work then removing the ball joint
thanks in advance
thanks in advance
Well...first, that and many others (some are red in color) are a copy of the Megan Racing front upper control arms for the OLD is300. They do fit the IS and GS 350/250 with minor adjustments, some washers where they bult to the inner frame...BUT the thing is, they either match camber or and MORE NEGATIVE camber (depending how u adjust the upper bolts)..Ussualy u want to add more possitive camber to cancel the negavite camber caused by lowerring a car...SOOO, if ur car is lowered and u want to correct camber back to near stock, these "arms" will actually make it worse...They can be modified though so that they can actually help correct camber (cutting and welding those arms)..But again, installed unmodified they will make neg camber worse...
thanks for the response, yeah i was trying to get positive camber, tires arent lasting very long and 19s are expensive
im going to order the ball joints instead then, thanks again bro
