Taillight Issue after brake job
Old 04-26-11, 11:26 PM
gsVIPdream
gsVIPdream's Avatar
Default Taillight Issue after brake job
so i just did my bakes this last weekend. and it seems when i was bleeding the lines my TAILS went out. my brake lights seem to work fine its just the tail lights which i need so i dont get pulled over. i know that its something to do with my fuses cause ive blown about 5 since saturday. i need help asap before i make an expensive trip to a mechanic. yet again this might be my only option ://.. thanks for any help like to here any help right about now
Old 04-27-11, 05:56 AM
Redline26
Redline26's Avatar
do you have LED tail lights or are the OEM?
Old 04-27-11, 09:16 AM
PHML
Master Thread Closer!!
PHML's Avatar
Bleeding brakes do not affect taillights. Must be coincidental. Which bulbs are out?
Old 04-27-11, 06:25 PM
gsVIPdream
gsVIPdream's Avatar
The tails only brake lights work an so do my turn signals
Old 04-27-11, 09:23 PM
aprince1
aprince1's Avatar
Start small and check the bulbs first.
Old 04-27-11, 10:45 PM
gsVIPdream
gsVIPdream's Avatar
Already checked is put a new fuse in and it will blow 5min later
Old 05-02-11, 05:43 AM
Redline26
Redline26's Avatar
try using a 20A fuse instead of 10A. Again do you have aftermarket LEDs or OEM tails? i'm tryn to help you here buddy but you didnt even answer my first question..I've had the same problem with my LED tails, but now they're fixed.
Old 05-02-11, 11:13 AM
geeznuts
geeznuts's Avatar
Check the fluids and get a tune up lol
Old 05-02-11, 02:40 PM
dejavu157
dejavu157's Avatar
going a bigger fuse might be bad. its blowing out for a reason. if u go a bigger fuse, u might start melting wires
Old 05-02-11, 03:53 PM
ThomasGS4
ThomasGS4's Avatar
If you have LED tails, this thread makes sense.
Old 05-03-11, 07:26 AM
sakataj
sakataj's Avatar
WHAT? please stop giving advice if this is your advicce
x2
LexXxtacy
01-27-12 01:03 PM
Sick03L
02-20-11 11:46 AM
CrystalGS3
03-15-10 07:20 AM
sgvdd525
01-24-10 02:30 PM
Quick Reply: Taillight Issue after brake job
