For those of you with Daizen Bushings...
I've had mine for 3 years on all arms in the front and I never had an issue. Make sure you use all the grease packets provided by Daizen, otherwise you're doing it wrong.
If you have stock springs, I would advise against polyurethane bushings on anything else but the castor arm. The stock spring might be too soft to overcome the additional resistance from the polyurethane and make your suspension travel somewhat "sticky".
My car is 100% stock and it's wandering all over the road. 01 430 with only 53K....brand new tires, alignment and still wander....I've read tons of info about this problem and most mentioned the culprit being caster arm bushing (which is #2 Lower Suspension Arm)....So from what I am reading, if I am replacing this bushing ONLY with the Daizen one, it will not have squeaking and will not impact (harshen) my ride? I'd like the smooth lexus ride....
Can someone confirm that?
Mine squeak going outta the driveway bump first thing on a cold morning. After riding around for a bit, they quit squeaking. As long as it's above 40-50 degrees though, no squeaky.
