I got the rear squeaks!
My rear suspension is squeaking at low speeds. When the car is parked and I rock it back and forth it squeaks. When I bounce the rear up and down it does it as well. Same for when I exit the vehicle. I just got daizen sway bushings installed last May. I am not sure if that could have something to do with it as well. I suspect it is shock/strut related at this point. What do you guys think? Thanks!
Check this out cuz I got it too and I doubt it's ur struts but I could be wrong
https://www.clublexus.com/forums/sus...on-squeak.html
I had similar problem. Tried alot of stuff. Replaced both rear Trailing Arms and Assembly with updated ones. Seems to have worked. i hope this helps
