Entire Front End Rebuilt
#32
![](http://i861.photobucket.com/albums/ab178/yotarover/Snapbucket/2b4caeec-orig.jpg)
![](http://i861.photobucket.com/albums/ab178/yotarover/Snapbucket/29c2aae7-orig.jpg)
any chance that the diffrence between mine and his new ones could cause the train like noise. just trying to keep narrowing things down till i can get outside and tear into it.
#33
What differences do you speak of? That's actually my car ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I know this sounds horrible to do, but you need to take a LIGHT degreasing solution (simple green, mix it 50/50) and spray EVERYTHING down.
Grab a cheap set of Microfiber clothes and start working on cleaning everything up (while being gentle on the boots of sway bar end links, UCA, LCA, etc).
#34
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
i swear i wasn't having to take radiation treatments and i had my full strength and everything back i woulda done had this solved.
#36
yes it did but when i checked everything it was all in tact. some how that bolt was coming out and it finally did. took me 30 mins to go find a bolt at tractor supply then it wouldn't thread all the way though the bracket. so i drove to a tire shop and they threaded it down. i'll order the factory bolts from lexus tomorrow and retread my brackets and caliper. but it hasn't sounded like a train all day and rides and sounds like it did the day bought it.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#38
If they are torqued down vibrations can cause them to come loose. I want to say use a TINY amount of blue loctite but you better be ready to break out an impact next time you go to take the bolts back out.
#42
alright this is getting annoying. like i said i replaced the bolt with one from tractor supply well last night i was coming home and it started again. so i called lexus at 9am those bolts are 15$ each + 10 shipping cause they dont keep them in stock. went to the junk yard and found another 95 and got almost brand new no nicks or scratches or rust bolts for 4 bucks for both.. tech is it possible for the inner part of the rotors to wear out and cause the vibration issues? it wont sit upright w/o falling off the hub. had to use a lug nut to realign it just to get the caliper back on it and line up the holes
#44
im changing the rotor cause it's sending the top bolt out now. . and for a quick fix after i add loctite to the new bolts. im gonna add a small tac weld. to the bracket and caliper to keep it from falling off while going down the road.
#45
You can download the entire FSM for free as well on this car (SC400). I need to find a file host so I can upload my copy as all the other locations are crappy.
Do not use a lot of loctite or else you'll never be able to get it back out.
The inner rotor on the fronts shouldn't wear out at all, thats normal for the lug nuts to hold it down as our cars don't have screws in the front (which are used for only keeping them in spot on putting a caliper).
