Rotor resurfacing and brake pad changed. however
i just changed front brake pad to ebc red and rotor resurfacing job done.
but it still makes noise...
how long does brake takes to settle down?
I had the ebc redstuff installed about 400-500 miles ago and im still getting the squeals. They recommend driving for 500-1500 miles in them to get rid of the squeals. I live in the suburbs so it will probably take longer for mine to bed in.
Yes, it's definitely embarrassing too, LOL! They were producing a lot of brake dust up until recently. The dust seems to be decreasing with more use. The squeal is still there but, it's not as loud as before. I didn't really feel much improvement compared to the OEM pads. I honestly don't think these are worth buying again and will be going back to OEM dust-less pads for my next set. I just can't stand the squeals that comes with these pads. I'll keep you updated on the next few hundred miles...
Hello i have the same issue too.But different set up on pads or rotor.I took to a local break shop.i took them like 5x but still have squeaking issue.i was looking on sewel luexus on breaks parts.It stated that we need to get a new shim kit on every new pad change. Im about order some. i hope it work for me. I keep you guys updated=)
Those of you who replaced the pads, did you clean and relube the shims and the pad's backing plate with caliper grease before installing?? This is likely the reason why you are still getting the squeaks and squeals.
2v1g
12-02-16 06:40 AM
