Question about Coilover Spring Rates
so i'm planning to get BC racing coils but i am having trouble what spring rate i should go with.
my ultimate goal is trying to get close to stock ride comfort as i can
From what i heard TEIN CST is the closet you can get but BC racing can revalve the coils to match the CST
but i've been hearing CST is too soft .. and the default BC racing settings are good enough..
so i want to ask ppl who tried either or had both to give some in put
also .. how much stiffer/softer does the adjustment on the coils give ?
let say i go with 8kg/7kg on Bc racing .. and i adjust the coils to stiffer.. would it push it to be as stiff as 10kg/9kg? and vice versa?
thank you
thank you
I had the same issue, want to retain stock comfort as much as possible. I went with the standard 8/10 and love them. Before installation I set them to 15, middle, on all 4. The ride is a little bumpier then stock on 18" wheels. But for the most part its not to far off of stock comfort. Plus Im going to adjust them softer when I get a chance. I called BC directly about spring rates. The said I should just go with the standard set up. Anything softer could be to bouncy causing my fenders to rub.
Phresh2010
Suspension and Brakes
12-26-11 01:17 PM
