just wanted to know whats the max negative camber that you can achieve with the factory rear camber adjustment in the rear on a slammed car just wanted to see if i need to purchase adjustable rear arms to get the fitment rite on my hopefully soon to come 10.5 +12 wheels thanks
from what i have seen... u shouldnt have much problem fitting that as long as you shave your fenders nicely and tire choice.. maybe pull the fender a little bit.. not 100% sure tho
anyone know how to adjust it though and how much you can? I'm trying to run a bit more in the rear to have better clearance on my wheels since I rub now, even with shaved fenders
how to adjust camber? easy. loosen the nut that tightens the camber belt and turn the camber bolt. Adjustment is only a few degrees tho. dont have a definite answer for how much.
Camber adjustment is right next to the whole hub in the rear suspension.
I think the most ive seen "natural camber" with all factory adjustments and no arms or bolts / bushings whatevers was like -5.5 or -6ish depending on how low the car is
