Help! [which front brake pads]
you could also put some collinite 845 on your wheels after cleaning and claying them. It seals the clearcoat so the brake dust won't stick as easily and will be easier to wash off as well
I have to admit that I for one don't like the dustless brake pads. There's almost no real bite, and frankly it's more than annoying. They came with my IS350 brake upgrade, off a brand new car.
The stopping distance is to say the least around the same, although the bigger calipers give you the "feel" impression, my IS250 oem brakes stopped the car at a slightly shorter distance. Of course this would change on repeated stops with the bigger brakes, not so much with the dustless pads though. They're quite useless at high demand braking.
No bite = to more episodes of ABS, with the high dust pads I was able to slow down and modulate a lot better. It honestly bothers me the effect it has on my braking. Although they will stop the car in the same distance as any others, for all other purposes slowing down is just pointless.
I was so dissapointed with the feel of them that I almost ordered some Carbotech XP10's to make it up. I will be ordering some StopTech pads or EBC pads. Something with a bite, dust never phased me.
See that's exactly the opposite of my experience.
The high dust pads are terrible if you want to modulate the braking... they're an on/off switch. You have a choice of not braking or a LOT of braking.
The low-dust pads allow a much greater range of braking to take place with the pedal.
Stopping distance is of course exactly the same because the pad doesn't have any impact on it.
