Sway Bar Bushings
Old 05-22-11, 09:22 PM
TechGreek
TechGreek's Avatar
Lightbulb Sway Bar Bushings
I got bored today and decided to put in the Polyurethane Sway Bar Bushings and HID's for my fog lights.
It made a pretty big difference for such a small upgrade.
Old Ones:
Here you can tell how bad the rubber has "flattened" out
And the new!
The brand new front end setup:
Fog Lights Installed:
Old 05-22-11, 09:32 PM
moosejaw2
moosejaw2's Avatar
Where did yo pick up the bushings at?
Old 05-22-11, 09:39 PM
TechGreek
TechGreek's Avatar
I got them @
http://www.prothanesuspensionparts.com/
It's obviously a drop shipper but the customer service has been great
Old 05-23-11, 01:27 AM
abounly
abounly's Avatar
Hmm for 9 bucks thats chump change!
Debating if i should do it now..
Old 05-23-11, 07:17 AM
TechGreek
TechGreek's Avatar
I highly recommend it. It may induce just a little bit of under-steer but it makes cornering more predictable in transitions.
Old 06-26-11, 08:34 PM
scotia
scotia's Avatar
did you do any modifying for the fogs? also in the low beams up top do you still have the projectors in? i do on my and reall dont know how i like them. i still have the yellow bulbs next to them did you swap yours? im mostly wondering why your whole light is glowing when mine only does some and you can see the little yellow one in it
Old 07-10-11, 03:16 PM
TechGreek
TechGreek's Avatar
Sorry just now seeing this! Scotia, yes the entire setup in the fog lights has been hard wired in. It's not a plug and play installation by any means but if you've got a little soldering skills, some heat shrink, and some electrical tape you should be ok!
I replaced the running lights with LED's from Luxury Mods.
Romanova
05-07-18 07:46 AM
MikeFig82
09-16-16 07:32 AM
Boomin
03-30-15 02:55 PM
bt430
06-22-11 06:44 AM
Champstar
10-20-10 07:02 PM
Quick Reply: Sway Bar Bushings
