Negative camber with only coilovers??
Old 05-23-11, 07:32 AM
sick
sick's Avatar
Default Negative camber with only coilovers??
Is the camber adjustable in the rear without camber arms? I'm looking to add a little camber to keep my tires from rubbing.
Old 05-23-11, 07:53 AM
Kurtz
Kurtz's Avatar
Camber isn't adjustable front or rear on RWD models without aftermarket parts
Old 05-23-11, 08:11 AM
sick
sick's Avatar
Damn, that sucks. I was trying to get away with not running a smaller tire.
Will lowering it give me more -neg camber?
Old 05-23-11, 09:33 AM
Bigrahizzl
Bigrahizzl's Avatar
^^^ the lower u go more Neg camber u will have
Old 05-23-11, 11:07 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I bought the Megan rear camber arms and tucked them in.
Attached Thumbnails Negative camber with only coilovers??-wheel-shot-deep-dish-.jpg
Old 05-23-11, 11:09 AM
Bigrahizzl
Bigrahizzl's Avatar
^^^ hows ur tread wear with that setup?
Old 05-23-11, 11:26 AM
Sffd103
Fire Slayer
Sffd103's Avatar
haha.....don't even ask!!!! I'm probably gonna buy the Figs Mega Arms (lower control arms) to bring it in from the bottom a bit.It's tucking rim though Shooting sparks too from my F Sport chassis brace too!
Old 05-23-11, 11:29 AM
Bigrahizzl
Bigrahizzl's Avatar
^^^^ Damn dude, that is some crazy stuff hahahaha.
I just want to balance out my negative camber in the rear. You thing Megans is good for this our should i get figs. I wont be tracking just regular street use
Old 05-23-11, 11:59 AM
sick
sick's Avatar
I guess i'll try lowering it some more to get the clearance i need. If thats not enough i'll look into a camber arm.
If i go with the figs mega arm, do i need the toe arm too.
Old 05-23-11, 01:07 PM
Sffd103
Fire Slayer
Sffd103's Avatar
The Megan's are designed for that. To even out the camber to positive if you have too much negative camber. You should be fine.
First off the Figs is about $425ish. If you do an alignment, that'll tell you if you need to adjust toe.
Old 05-23-11, 06:04 PM
CarbonDtls
CarbonDtls's Avatar
Need to get the Megan camber kit. Done.
Old 09-06-11, 01:43 AM
CCJ22
CCJ22's Avatar
How low are you? I dunno if you'll need a rear camber kit Big... I wonder if we could add some washers??? I should crawl under my car and see.
Spamboi
06-18-15 08:39 AM
ozzy250
Suspension and Brakes
04-19-13 12:42 PM
Lanceezy
12-02-12 11:26 PM
671IS250
06-13-11 10:28 PM
NemeGuero
11-06-09 09:05 AM
Quick Reply: Negative camber with only coilovers??
