Rear Camber Adjustment.
One really excellent way to correct the camber and toe on your rear tires, is to get rear adjustable lower control arms and adjustable rear toe links...Here's an example of mine's that I had done recently...
![](http://i29.photobucket.com/albums/c272/Gonzales005/282794_230187513688779_100000925966984_658918_2374152_n.jpg)
![](http://i29.photobucket.com/albums/c272/Gonzales005/284207_230187310355466_100000925966984_658912_5311753_n.jpg)
![](http://i29.photobucket.com/albums/c272/Gonzales005/281854_230187480355449_100000925966984_658917_3492509_n.jpg)
When I got it aligned, The guy (Yoshi) was doing all the rear adjustments through the newly installed parts, My front's now sit at -1.9, the rears at -1.5 and zero toe on all fours (Since that's what I wanted) and the steering wheel is now straight.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
http://eaurouge.jp/parts/
If anything, Drift Speed should be able to get you the parts with no problems at all.
Here's the website that Drift Speed got the parts for me, from...
