Tie Rod issue?
Old 07-01-11 | 08:38 AM
ThomasGS4's Avatar
ThomasGS4
The ball joints have been replaced with an alignment following. The car is 100% again. Feels like a whole different car.
Old 07-01-11 | 01:22 PM
lexusben's Avatar
lexusben
So did you end up replacing the tie rods and steering rack bushings as well?
Old 07-01-11 | 02:13 PM
ThomasGS4's Avatar
ThomasGS4
Negative. I'll replace the steering rack bushings next.
Old 07-03-11 | 01:24 PM
CptCrunch's Avatar
CptCrunch
Thomas,
did you use OEM ball joints? im going to do this soon since my car wants to wander on the freeway and loose steering. why didnt you replace the tie rods?? they look like they need replacing. do you really need an alignment after ball joints? i thought we only need it when we mess with tie rods..
Old 07-03-11 | 01:59 PM
ThomasGS4's Avatar
ThomasGS4
Yes, OEM ball joints.
Truthfully, you should get an alignment each time you have suspension or steering work done since the suspension is out of balance.
Old 07-03-11 | 02:36 PM
CptCrunch's Avatar
CptCrunch
is there a reason why you didnt change the tie rods? mine looks fine but im not sure if i should only change the ball joints. seems like you have a big improvement just changing the ball joints.
Old 07-03-11 | 02:51 PM
ThomasGS4's Avatar
ThomasGS4
I don't think I had any improvement with the ball joints.
My problem was a much needed alignment.
Old 07-03-11 | 02:56 PM
CptCrunch's Avatar
CptCrunch
ohhh okay.. thanks!
alteredego
04-29-12 03:53 PM
awd_pwnz
01-25-10 12:34 PM
CP_Ree
Performance & Maintenance
01-03-10 09:19 PM
scfocus
Suspension and Brakes
12-07-09 12:13 AM
