Adjustable Sway Bar End Links
what about these? im sure they could work for the rears as well. What you guys think?
http://store.driftmotion.com/static/i-bpm-202-09.php
EDIT: I just did a search on fleebay (ebay) "adjustable sway bar links" and there are tons of them out there for other cars and I am sure that you can find somthing that will work for the SC? Im interested in this as well. Let us know if anyone has bought a set for another car that fit the SC
OK found some specs for that blox kit. They dont look to bad at all just grease em up real good and I think it should be fine. I will messure mine out tonight (front and rears) and see if they will be compatable. For 36 bucks... couldnt hurt to give it a try right?
Specifications for the Blox adjustable links:
CENTER TO CENTER: 2.8” min; 3.5” max
BOLT SPEC: 10x1.5
BOLT LENGTH: 2.75 (bolt might be to long but you can replace that no prob.)
BOLT SPEC: 10x1.5
For under $100 we might be able to use them in the front and rear. and for that price that cant be beat.
I made them short cause the car is alot lower than stock so using stock height links wouldnt work
you need:
Economy Rod End Male 3/8-24 RH x 4
Economy Rod End Female RH 3/8-24 x 4
Steel Jam nut 3/8 x 4
Zinc Plated Cone spacer 3/8 x 24
THAT stuff I bought from www.racingrodends.com they are paypal friendly and shipping was cheap it was around $50 for everything
THen I had just went to my local hardware store and bought:
2" long hex head bolt 9/16-24 x 8
and then some locking nuts in 9/16-24 x 8 of them
The bolts and nuts were a few dollars
Here are how the fronts look
![](http://sterlz.files.wordpress.com/2012/04/img_20120409_123933.jpg)
And here are the rears, The bar sits lower then the control arm now cuz of the ride height
you need:
![](http://sterlz.files.wordpress.com/2012/04/img_20120409_131720.jpg)
