Adjustable Sway Bar End Links
Old 06-10-11, 06:44 AM
TechGreek
TechGreek's Avatar
Question Adjustable Sway Bar End Links
Does anyone know of them for our cars? My front sway bar end links are putting a lot of tension on the LCA and preloading it from what I can see visually.
Yes, they are the right ones on there.
Old 06-10-11, 07:41 AM
Luv2xl
Luv2xl's Avatar
you can certainly make one..
Old 06-10-11, 11:41 AM
TechGreek
TechGreek's Avatar
I know I could, but I don't WANT to make one - I would rather buy a set pre-done so all I need to do is adjust.
Surely with as stupid low as some of you are you've found a solution by now? I know you're eating up sway bar end links if you haven't...
Old 06-10-11, 02:58 PM
ArodDaLob
ArodDaLob's Avatar
you really don't have much of a choice. stock or make your own. my solution was to make my own.
Old 06-10-11, 04:21 PM
TechGreek
TechGreek's Avatar
Hmmm, have a DIY or interested in making another pair?
Old 06-14-11, 10:18 PM
OneJay
OneJay's Avatar
You could probably even get some made for another car that would fit ours just fine. I'm thinking of trying out my friend's that he used to have on the rear of his tC. I'll let you guys know how they fit.
Old 06-15-11, 02:29 PM
Sullen0313
Sullen0313's Avatar
buy a set on ebay, get a sleeve from a metal shop, get a threaded rod and 8 nuts to match. cut your new links from the center shaft and weld the threaded rod to them. weld a nut to either end of the sleeve. thread your new setup together, and install on the car...
Old 06-15-11, 02:35 PM
92blacktt
92blacktt's Avatar
thats a lot of work and waste, you can buy rod ends on mcmastercar or fastenal and just buy the nuts, bolts and threaded rod.
check out rod ends here: http://www.fastenal.com/web/search/p...nd&Ntt=rod+end
I would use a female rod end and then just buy threaded rod and cut to length, or even better to use a stud to the correct size.
http://www.fastenal.com/web/search/p...=stud&Ntt=stud
Old 06-15-11, 02:53 PM
TechGreek
TechGreek's Avatar
I thought we weren't supposed to use those type of joints, only automotive grade?
Old 06-16-11, 06:01 AM
Sullen0313
Sullen0313's Avatar
yea, we fab **** here at my work all the time... maybe i'll post some pictures of some things so you guys can see some nice eye candy.
Old 03-05-12, 10:27 AM
AnonymousG
AnonymousG's Avatar
Anyone ever find out anything? For the rear I'm thinking about using the Blox honda kit, but what about the front?
Old 03-05-12, 12:28 PM
BenStoked
BenStoked's Avatar
http://www.google.com/products/catal...d=0CIABEPMCMAM
Old 03-19-12, 07:50 AM
NerdRiot
NerdRiot's Avatar
Has anyone actually tried these? If so, how well do they fit? Any modifications needed?
Old 03-19-12, 09:36 AM
8052JZ
8052JZ's Avatar
what about these? im sure they could work for the rears as well. What you guys think?
http://store.driftmotion.com/static/i-bpm-202-09.php
EDIT: I just did a search on fleebay (ebay) "adjustable sway bar links" and there are tons of them out there for other cars and I am sure that you can find somthing that will work for the SC? Im interested in this as well. Let us know if anyone has bought a set for another car that fit the SC
OK found some specs for that blox kit. They dont look to bad at all just grease em up real good and I think it should be fine. I will messure mine out tonight (front and rears) and see if they will be compatable. For 36 bucks... couldnt hurt to give it a try right?
Specifications for the Blox adjustable links:
CENTER TO CENTER: 2.8” min; 3.5” max
BOLT SPEC: 10x1.5
BOLT LENGTH: 2.75 (bolt might be to long but you can replace that no prob.)
Old 03-19-12, 01:53 PM
NerdRiot
NerdRiot's Avatar
^ very interested to hear what you find.
Quick Reply: Adjustable Sway Bar End Links
