Cut my Fender on IS350
I decided to cut a few spots where the fender was rubbing, for now it seems like most the rubbing has stopped with the exception of going over extremely large bumps.
I am lowered on BC Racing Coilovers and have stock wheels / tires.
http://i53.tinypic.com/35l94pg.jpg
I'm a little scared of that plastic clip / metal part / and getting water in my lights or damaging the harness.
I know a lot of people hammer out the metal piece but I just assume leave it if its not rubbing extremely hard.
Please let me know if I risk messing anything up without correcting this.
Thanks
Thanks
the rubber seals in the 2is headlight and foglight housings should be water-proof. unless there is a history of moisture build-up in them, you should be fine with trimmed section of the fender liner.
on a related note, your 2is has to be REALLY low to cause tire-fender liner wear in that area. unless you're on taller-than oem-sized tires, you'd have to be really slammed for the tire to rub against the top of the fender liner
paulwall4
RC F (2015-present)
15
09-25-17 02:12 PM
melski415
08-21-11 05:56 PM
chrispy
02-06-08 12:43 PM
