Bilstein HD
Old 07-03-11, 01:49 AM
amichie
amichie's Avatar
Default Bilstein HD
Hi
Do the Bilstein HD shocks to suit the 2nd Gen GS300 have the height adjusting circlips with multiple grooves?
Andrew
Old 07-04-11, 09:28 PM
Agent0024
Agent0024's Avatar
Look like it does.
Old 07-05-11, 02:59 AM
amichie
amichie's Avatar
Thanks. Got some on order now. Most likely I will use the stock springs and set the circlip in the lowered position.
Old 02-16-12, 04:57 PM
sam12345
sam12345's Avatar
How do you like your set up?
Old 02-21-12, 01:57 PM
gsCrazy
gsCrazy's Avatar
so the rear shock height can be adjusted? i have bilstein hd's installed in my gs300 and noticed that after the install the rear wheel gap increased.
Old 02-27-12, 01:40 AM
amichie
amichie's Avatar
Yes the circlip height can be set about 15mm lower.
Old 02-27-12, 09:19 PM
sam12345
sam12345's Avatar
I put mine on the lower position (they come shipped on the upper position) it dropped the car about 3/4" from stock height
Old 02-27-12, 11:20 PM
amichie
amichie's Avatar
Are you happy?
Old 02-28-12, 05:26 AM
gsCrazy
gsCrazy's Avatar
What about the front shocks? Are tu adjustable too?
Old 02-28-12, 04:08 PM
sam12345
sam12345's Avatar
Yes both front and back have two positions yes I am happy it feels like the oem shocks but as if you added 10 more psi to your tires. Got rid of the
marshmallow ride. Much better damping, better handling and better over big bumps. I still have too much body roll but I need to change sways for that
Old 02-28-12, 08:29 PM
NEbiker10
NEbiker10's Avatar
Interesting. Wonder if these would be sufficient when upgrading to 18's to take care of wheel gap?
Old 02-28-12, 09:03 PM
raytseng
raytseng's Avatar
yes, both f/r have 2 perch positions, but i don't think it will be 3/4" it will be more like 1/2" or less (1 skinny finger).
You will not be able to notice much difference in height from stock. You really need to use something purposely intended for lowering to make a dramatic difference.
Old 02-28-12, 09:20 PM
sam12345
sam12345's Avatar
Yeah you hardly can see the difference the gap is more even all around the tire only reason I could tell how much it dropped was by the clearance to my jack. I did not actually measure the drop just a guesstimate
Chlim1122
Suspension
09-25-17 06:37 AM
RRocket
03-31-16 01:00 PM
angus
Suspension and Brakes
11-01-14 01:44 AM
gsCrazy
09-20-08 11:46 PM
Toyo-Lex
06-02-05 02:06 PM
Quick Reply: Bilstein HD
