JIC from a JZX90 Toyota Tourer on a SC?
Old 07-08-11, 11:58 AM
Turbo?
Turbo?'s Avatar
Default JIC from a JZX90 Toyota Tourer on a SC?
anyways my buddy just gave me his old set of JIC magics from his Tourer V Mark II. and for some reason it wouldnt fit the SC. Anyways i was curious if there was a way to retro fit these? or is it just better off to sell this set and get some SC ones?
Anyways if so what other vehicles share the same suspension as the Mark II. and what other chasis codes fits SC suspension?
let me know!
Old 07-08-11, 12:05 PM
Kohinoor
Kohinoor's Avatar
sell them.
jzs147 1st gen gs300/aristo, jza80 supra, and jzz30/31 sc/soarer will fit.
Old 07-08-11, 12:06 PM
Turbo?
Turbo?'s Avatar
damn!!! what do the JZX90 fit?
Old 07-08-11, 12:12 PM
88supramki
88supramki's Avatar
Chasers....
Old 07-08-11, 12:14 PM
Turbo?
Turbo?'s Avatar
lol i know just thought it fit other vehicles!
Old 07-08-11, 12:21 PM
CHASER4LIF
CHASER4LIF's Avatar
no it wont.. that will work on the mk3 supra from what guys are telling me.. better of going to www.jzxproject.com and put it up for sale son!!
Old 07-08-11, 12:26 PM
Turbo?
Turbo?'s Avatar
thanks man!
Old 07-19-11, 03:53 AM
soarer13oy
soarer13oy's Avatar
Originally Posted by Kohinoor
sell them.
Can anyone verify this? I can get a set of coilovers for the jzs147 for a good price if someone can verify it.
Old 07-19-11, 06:54 AM
Kohinoor
Kohinoor's Avatar
they all have the same mounts. valving and spring rates may vary depending on the brand/model, but they will fit nevertheless. the 1gen gs is basically a four door sc/supra.
http://www.toymods.org.au/forums/tec...ies-jza80.html
Old 07-19-11, 10:43 AM
soarer13oy
soarer13oy's Avatar
Thanks kohinoor now i can get a set of used coils for cheap =)
Old 07-20-11, 12:40 PM
Turbo?
Turbo?'s Avatar
maybe the front will but the back will not fit unless you retro fit it. I checked the suspension on the SC and the mounting in the rear is completely different.
Old 07-20-11, 01:03 PM
Luv2xl
Luv2xl's Avatar
how about if you use the top hats from the old suspension? Also as for the mounting lower mounting point, drill a hole, thread it and install a locking heim joint and you are done..
Old 07-20-11, 01:36 PM
Kohinoor
Kohinoor's Avatar
you may be talking about the jzs161 (2nd gen gs) which has eye bushing mounts all around.
if the question is whether jzs147 coilovers will bolt up - yes, they will. jzs147/jzz30/jza80 all use the same eye bushing mounts up front and forks in the rear. whether the spring rates, valving, spring length, etc is the same is something completely different and i have no idea - ask the manufacturer.
if you want jzs147 coilovers over jza80/jzz30.. by all means do the research and decide for yourself. i see no reason to buy them over something specifically made for your application, though. do not go by my word alone.
here are some links i found that may help someone decide
http://zilvia.net/f/sale-items/31643...pra-jza80.html
http://www.ebay.com.au/itm/Tein-HA-C...-/250846368427
https://www.clublexus.com/forums/6121882-post6.html
http://page10.auctions.yahoo.co.jp/jp/auction/m86053024
http://forums.jdmvip.com/showpost.ph...5&postcount=18
https://www.clublexus.com/forums/1737272-post5.html
http://www.japandirectjapanese.com/p...&cat=22&page=1
http://www.vipstylecars.com/forums/s...76&postcount=5
http://www.youtube.com/watch?v=1-rK-3xuWwk
Old 07-20-11, 07:12 PM
Turbo?
Turbo?'s Avatar
ya for sure man but the suspension is from a JZX90 Tourer V (MARKII)
it will not fit SC's
Old 07-20-11, 07:55 PM
horent135
horent135's Avatar
For a fact I done this before. jzs147 coilover will fit for the SC. BUT... your rear will sit higher because of the valve and spring that was design for jzs147. I had jzs147 toms coilover on my SC. That was single adjustment. Im not sure when you have dual adjustment coilovers.
Quick Reply: JIC from a JZX90 Toyota Tourer on a SC?
