end links wont come off....
Old 07-12-11, 07:04 PM
rpx13
rpx13's Avatar
Default end links wont come off....
my rear passenger sway bar end link broke in half and i tried removing them, but ii think theyre rusted on there. Tried some pb blaster and that sucker will not budge....any ideas?.....thanks in advance....
here's a pic
Old 07-12-11, 08:15 PM
sayayin
sayayin's Avatar
Use a nose clamp pliers to hold the bolt and use a impact gun for the nut.
Old 07-13-11, 05:21 PM
parker770
parker770's Avatar
I had to cut my front links off with a torch and replace them because they were seized and stripped. End links are cheap enough to just cut off and replace.
Old 07-17-11, 07:44 PM
lownfastsc
lownfastsc's Avatar
i had to use a grinder to get mine off, it worked well. just grind the side of the nut till you go into the threads, then the nut should come off with ease.
98GSOwner
Suspension and Brakes
03-20-18 01:49 PM
99rx
12
09-03-16 06:45 AM
KawiLex
08-03-16 04:58 AM
Vibes63
06-27-12 06:52 AM
funglenn
17
01-10-12 11:21 AM
Quick Reply: end links wont come off....
