BCR coilovers
Hi guys i am really thinking about getting the BCR coilovers, i am a total noob at this i am wondering if i would need to adjust the stiffness of the coilovers after having them installed on my car. Do i need to take them off every time to adjust the stiffness or that can be done while the coilovers are on the car?
Also, for the budget of buying a set of BCR coilovers, are there any other better suggestions?
Paid about a grand. Definitely a noticeable increase in handling. Ride quality suffers a bit but, if you keep messing with the stiffness/softness settings, then you can get it pretty close to stock quality.
I think you're talking about the body roll. The coilovers gave the car a better steering response. As for the body roll, I still get a bit of it when cornering. I see that you already have the sway bars installed. I think you will notice a significant decrease in body roll after lowering your car. Maybe someone can chime in a little more.
Ordered my BC's from CircuitMS, they were able to beat all the other vendors in terms of price and service was great. Be careful dialing in the height too low. Lower you go, more you have to modify fender liner, rolls fenders, modify fender/bumper tab, etc.. Regarding adjusting the damping, the adjuster ***** are on top of each shock. Like some said, the front adjuster ***** can be accessed under the hood. The rear the side panels are covering the adjusters *****. Some ppl suggest pulling the panels back to access the rear adjusted *****, but I find that a hassle. BC sells rear extenders so the ***** can be adjusted through the trunk liners. I custom cut the my rear extenders, can't have it super long sticking out.
