Help !! Abs/asc/brake/ and beeep noise!
Old 07-13-11, 10:28 PM
phamxOC
phamxOC's Avatar
Default Help !! Abs/asc/brake/ and beeep noise!
So today after dinner, i camee out and the abs, asc, and brake lights were on. it also made this annoying beep noise. When I backed up the car, i notice the brakes would not brake correctly. any ideas ?? i need help asap!
Old 07-13-11, 11:50 PM
GS4_Fiend
GS4_Fiend's Avatar
check fluid level..
Old 07-14-11, 12:10 AM
phamxOC
phamxOC's Avatar
seems normal..
Old 07-14-11, 12:18 AM
GS4_Fiend
GS4_Fiend's Avatar
your brakes are probably worn. the reason why hear the beep is that the master cylinder has detect a low fluid level and warns you. check out your whole brake system. And when you brake, the pedals starts to sink down, master cylinder is gone.
Old 07-14-11, 12:33 AM
phamxOC
phamxOC's Avatar
i just replace my front brake pads about 1500k ago, and when i step on the brakes, it feels really solid and does NOT sink down....
Old 07-14-11, 05:44 AM
98Gs4001UZ
98Gs4001UZ's Avatar
Had the same problem after washing my car. It did the exact same thing for about half the day. Then I let it sit for the rest of the day and all through the night. Got up the next morning and it stopped doing it. Fluid level was fine. Pads were fairly new. I never could figure it out.
Old 07-14-11, 08:26 AM
runyun
runyun's Avatar
What yr is your car? This was apparent on the 98-00 2nd gens
It makes a constant buzzing sound (intermittant). And eventually, you will lose your power assist when braking (very scary)
Old 07-14-11, 11:17 AM
GS4_Fiend
GS4_Fiend's Avatar
get the ABS codes checked out. that's your best bet. a regular generic scanner is not capable of retreiving ABS codes.
Old 07-14-11, 03:22 PM
phamxOC
phamxOC's Avatar
i got the car scanned at a lexus specialist, and the abs module is out. if anyone has one for sale let me know asap!
Old 07-14-11, 04:09 PM
GSquicksilver
GSquicksilver's Avatar
it's your whole brake master cylinder assembly. the abs unit is part of the whole assembly, so you must change out the whole thing.
Old 07-14-11, 04:44 PM
porn-adkt
porn-adkt's Avatar
Wrong, the ABS can be removed by itself
Old 07-14-11, 04:51 PM
phamxOC
phamxOC's Avatar
thats what i was quoted at 3 differnt shops, but those unit at the dealer are like 1200, im trying to find a use one right now...
Old 07-14-11, 11:40 PM
bADBOySC4
bADBOySC4's Avatar
hey yo pham hit me up tomorrow. i might be able to help u out.
Old 07-16-11, 04:16 PM
phamxOC
phamxOC's Avatar
still need one
Old 07-19-11, 06:34 PM
92sc300nj
92sc300nj's Avatar
dude.. if you got a 98-00 gs.. almost 99% sure its your abs actuator.. uber expensive and very common to fail. dont know if you need the whole master cylinder (highly doubt it) but ya if you get a "used" one .. its going to do it to you sooner than later.. just get a new one.. and dont be cheap lol.
Quick Reply: Help !! Abs/asc/brake/ and beeep noise!
