Please Help a NOOB!!!
Hi guys,
First post here on this forum so I'll get to it. I have a 06 IS250 RWD and have had it since April of 06. I wanted to put some Eibach Sportline kit on it but is there anything else I should pair it up with ie. Bushings, Shock absorbers ect... I want minimal camber wear if possible or are the springs by itself sufficient enough? Please advise.. THANKS in advance guys!!!
Welcome to CL.....If you want Eibach's I think the drop won't be too much to have so much camber. Although Megan has a rear camber kit (about $200). There currently isn't a front camber kit for our cars. Some people have used SPC's front camber kit from an IS300 but requires modification. If you want stiffer shocks, then you can go with an aftermarket brand.
On a side note, don't forget to look at Sewell Lexus. They're a vendor on CL(click the vendor tab). If you register with them, you'll get a CL discount on ALL factory parts. I just purchased my spark plugs and oil filter. Have used them before for a bunch of stuff.
Reset:
https://www.clublexus.com/forums/is-...ml#post1723025
But you should probably go and look through this:
https://www.clublexus.com/forums/is-...tart-here.html
Great info for a newbie to CL (and it's required reading...)
