Front end still popping.
Two weeks ago I installed Megan ez coil overs, Lexus Lbj and lower control arms and new upper control arms. I still have a poping sound when I put the car in reverse or when I go from park to drive.
Any ideas?
Any ideas?
I had this same issue. it turned out to be, amazingly, the brake pads. There is a fitment kit for them. Some ofthe pads are just a hair too small, and when you are applying the brake and the pad is pressed against the rotor they can be moved slightly in the caliper. This caused a clunking noise when pulling out of the garage and when shifting into drive.
Johnhav430
12-13-18 07:39 AM
fooldall1
09-21-16 03:54 PM
