At what mileage is a brake job recommended
so my car is about to hit 40k and I was wondering when a brake job (brake pads, rotors..anything else?) is advised. I have a 08 Lexus is350. thanks for the input
brake fluid is recommended to be done every 30k.
brake pads are totally dependent on your driving style, but I see averagely they are around every 30-50k miles.
rotors are also totally dependent on your driving habits, but I see rotors lasting to 70k (basically twice the life of your brake pads). Rear rotors will probably last a good 120k.
Again, its all on your driving habits and a better check is to physically look at them yourself
Is it a hard job? And do you have to bleed the brakes after? I herd it's like some type of electricly bleed or somthing is that right. And are you always supposed to change the shims Cuase the dealer quated
$500 for what???? Geez, what a rip. Purchase the pads you want, jack up one side of the car, remove wheel, remove pin/bar across top of pads, pull pads out of the top of caliper, depress the pots/cylinders, install new pads/shims (or old OEM shims), install pin/bar, install wheel, lower vehicle. Duplicate process on the other side. Break-in pad according to the directions. OEM vs aftermarket performance pads have differing procedures...but all easily done in 10 minutes or less.
