rear struts blown
A shock absorber is a unit in which spring & bump stopper are arranged concentric (rather coaxial) with the damper to save space required for seperate installation of each.
A strut is a coil-over-shox with additional degrees of freedom for steering the wheel (provided by a bearing which partially replaces a ball joint) and articulation of the wheel (provided by the top mount which doubles in as the upper wishbone / control arm).
A strut is thus, a combination of a number of suspension components viz. spring, damper, bump stopper, upper control arm and probably one ball joint.
A strut and a coil-over-shox are not interchangable. If you put a simple coil-over-shox in place of strut, you won't be able to steer the vehicle and if you do otherwise, the directional stability will be lost. A strut is usually used in front suspension and a coil-over-shox is generally a part of rear suspension.
Sandi_k
RX - 3rd Gen (2010-2015)
22
12-23-16 12:05 PM
