steering wheel doesn't return to center position?
Old 07-28-11, 11:08 AM
mong
mong's Avatar
Default steering wheel doesn't return to center position?
So here's my problem.. when I drive on the freeway my car tend to go left a bit and when I make a left turn it doesn't return to the centered position. It would just stay left. Should I take it to the dealer? My car is a 2010'. you guys think the dealer will charge me if they don't find the problem?
Old 07-28-11, 11:50 AM
my95tsi
my95tsi's Avatar
Welcome to owning a 2 IS. It's just how it is. I've had 3 2IS's and all are the same.
Old 07-28-11, 12:06 PM
Gville350
Gville350's Avatar
What? So if you're parked with wheels pointed perfectly straight ahead your steering wheel will not be at a perfect 12 o'clock position?
Old 07-28-11, 01:49 PM
mong
mong's Avatar
I see............
Old 07-29-11, 07:32 AM
my95tsi
my95tsi's Avatar
What? Did you even read the post?
Old 07-29-11, 07:34 AM
my95tsi
my95tsi's Avatar
Originally Posted by mong
I see............
I've just gotten used to having to return it to center myself instead of letting it slide through my hands. I had an Evo before this and it didn't the same thing I didn't even think twice.
Old 07-29-11, 08:59 AM
B16da9
B16da9's Avatar
Sounds like an aligment issue to me.
Old 07-29-11, 10:39 AM
Gville350
Gville350's Avatar
Yep, and the thread title too : "steering wheel doesn't return to center position". OP didn't hardly detail to the extent his issues were...whether it be an alignment issue or a steering rack issue. Perhaps he has an aftermaket steering wheel that he incorrectly installed, thus causing the "centering" issue. Man, just trying to internet-diagonis a problem...think outside the box.
Old 07-29-11, 01:17 PM
mong
mong's Avatar
https://www.clublexus.com/forums/ls4...re-update.html found this..
seems like the ls460 is having a similar problem. Interesting..
Edited- My alignment is fine. Been to like 5 shops in the past 3 months. They all said is fine.
Old 07-29-11, 06:08 PM
Gville350
Gville350's Avatar
So it could be a electronic/electric steering rack issue...hmmmmm, who would of thought.
Old 07-29-11, 07:14 PM
mong
mong's Avatar
Hahaha. I'm gonna do some more driving test to know for sure. Will keep y'all posted
Old 07-30-11, 11:07 AM
Gville350
Gville350's Avatar
While you had those alignments done did you explain the issue you were having with the car to them? Did they advise you on anything you should look for?
Old 07-30-11, 02:46 PM
mong
mong's Avatar
Yes. So I did some more test driving U-turns and turns. My final conclusion is.. the car is fine. Is just doesn't come back with more force as I've come accustomed to. This is my first Electronic Power Steering System(EPS) btw. So that may be why I'm questioning it. I'm just gonna leave it at that
Old 07-31-11, 09:34 AM
Gville350
Gville350's Avatar
The electric PS does have a lighter rack feel to it when compared to a hydro rack. Hopefully the car is fine...GL!
Old 08-01-11, 11:39 AM
mong
mong's Avatar
I now think my tires are defective(hankook evo v12) cause all the veering to the left all started when I got the hankooks. After been to 5 different alignment shops.. iono what else it could be. =/
Quick Reply: steering wheel doesn't return to center position?
