Strut bars and braces
Hi all,
I have been reviewing the offerings for the 2 GS and would like input from people that have run different strut bars.
After looking at the deflection that happens on strut towers on various cars it seems like a rigid bar would be the best performing. The loaded strut tower tends to want to move in (towards the engine) and up (towards the hood). Strut bars with pivot points on the brakets seem to be less effective in containing this motion. Thoughts?
I am in the process of building a rigid bar with an adjustment point in the center of the bar to adjust preload. That is the type of bar I have built in the past for various cars with good results and I have not seen any off the shelf offerings for the 1st or 2nd gen GS with said adjustment. This would still provide a rigid bar with the "weakest" point being in the center of the bar at the adjustment point but a 1/2" thick pipe should be plenty strong to counter the forces.
The same questions and thoughts apply to the rear bar as well.
Also, any insight to the various body/crossmember braces that are available?
I have noticed that on a lot of GS's (as well as other cars) the body tends to deform around the sunroof. I believe that this is because of the lack of support in the center of the stock car which allows for body "twisting". I ran Do-Luc cross bars on the Supras and it substantially stiffened the car, even with the targa off. The Do-Lucs are mounted in the cabin but I have not seen any offering for the GS (either internal or external).
Right now I am running Tein coil overs w/EDFC, front and rear RCAs, Danzen sway bars and steerin rack bushings. I plan to remove the rear RCAs and go with FIG's rear Mega LCAs. On initial turn in the back gets a little "floaty" unless you put power into it but with the sways it has become a little less forgiving and tends to oversteer. Stiffening of the chasis I think will help to deal with this better (better tracking rear to front).
Any insight would be appreciated!
Thanks!
Thanks!
do luc USED to make a internal bar for the gs BTW, a turboed gs430 that was in superstreet had it...
im fixing to sell my carson replica one and get a custom chromemoly one made that will mount to my back firewall also. i got my TRD blue swaybars also but they havent been installed yet they getting powdercoated and im STILL looking for the TRD underbrace and the TOM's 6 point to stiffen up my chassis
Is the TRD underbrace just a front piece? Any pics or links?
I have been looking at the TOMs as well (love Hyperrev) but I have heard of people having problems with various pieces breaking. Dunno about that though.
I should have the car back in about two weeks from the body shop (all dings removed and new paint job) and I'll throw on the new exhaust and rear door sills :-)
Figure as long as I'll have it up in the air I might as well attach any recommended braces.
PM me how much you want for the strut bar.
How are you planning to attach to the firewall? The sheetmetal is fairly thin there. On the GS at least, I do not see how triangulation would help as the strut towers are fairly rigid and I do not see the forces that would push or pull them forward or back. I'm sure I'm just overlooking something though.
trd brace looks like this but is discontinued
http://www.l-tunedparts.com/product/?id=492
i have only seen one guy with a issue with the TOM's they were rusted and broke
Saw it on EBAY and gave it a shot. I got the Ultra Racing front 4 point under brace and front strut bar. Install was easy. The strut bar can be used with the TEIN EDFC (old or new motors). The picture is with the old (large) motors just to verify that they would fit. Small motors have plenty of room.
Didn't notice much difference in normal driving (expected) but I hopped up on Grimes Canyon and the two made a definite improvement.
Master Thread Closer!!
i have the old oem 1gen gs stb. it does not fit over the gs3 engine cover. as a matter of fact it rubs on my throtle body so i took it off. there is a 1/8" triangle ring that goes under the nuts on the top of the shocks. if i leave that on it clears with no issues but there is no threads left on the shock bolts. so the only thing i can think of is getting slightly thinner nuts? i have seen many member with it (i think carbongs had it originally)
Well, there are many GSs in California, some of the owners are friends of mine. One has a 98 GS4 and the bar fit fine. Another has an 04 GS4 and it fit fine. Both have ordered the bar. I tested on my car, a 2005 GS3 and no issues with the cover and either version of the EDFC motors.
Installed AD2R strut bar last week. I know its not JDM or Tein but I'm all about functionality!
Anyways, the wheel shaking I got after going 60+mph on the highway has significantly reduced. I would say AT LEAST 90% of the shaking is now gone. The steering is so much better on turns.
I recommend a front tower strut bar to every GS owner who is lowered.
Here are some pics:
Here are some pics:
