F-sport Spring only
Hi there,
I have a 2010 IS 250C convertible, thinking about lowering the car by about one inch or so. The problem is that there aren't many options other than F-sport springs/shocks for the convertible, which is about 400lb heavier than the sedan. Also the combo is expensive that definitely puts you into coilovers price territory. I am thinking about just lower the car with F-sport spring right now, and upgrade when I have more choice.
Lexus says the F-sport springs are compatible with stock shocks. But I heard the stock shock won't last long since the spring rate is different from stock spring. Does anyone have long term experience with this setup? Does it also make the infamous clunk noise?
Thanks,
Kevin
Thanks,
Kevin
This review mentioned "the car floats for longer than normal."
https://www.clublexus.com/forums/sus...in-shocks.html
You can get that floaty feeling when the oem shock isn't matched to the F-Sport springs. OEM shocks are on the soft side. With a matched spring/shock, you get better compression and rebound. F-Sport spring/oem shocks are still better than stock springs/oem shocks imo. With stock setup, it's always feels floaty and the body roll is ridiculous when cornering.
I'm also referring to the oem tanabe non-sport shocks. The sport shocks (sport package and F-Sport models) are stiffer with stiffer linear springs. F-Sport springs are progressive.
Cool. Did you experience any handling issue with the spring only setup?
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
You can do a quick search... there have been reports earlier that people who installed F-Sport Springs with OEM shocks will have ride problems in the future.
It feels ok in the beginning. But after a while, there have been reports that it's going to get very bouncy. That's expected because the OEM shocks cannot compensate for the higher spring rate of the F-Sport Lowering Springs. It will wear out your OEM shocks faster...
I would get them as a set because the F-Sport Springs were designed to be with the F-Sport shock. But you can use the OEM shocks as they advertised because it fits in there.
I have F Sport springs on the factory Tokico sport shocks. I have no complaints other than the increased noise inside the cabin. I feel the ride is exactly the same as the stock sport suspension but I do notice increased creaks and rattles especially on graded or grooved surfaces. I hear a lot of noise in the sunroof or roof in general for some reasom. IMO I would imagine F Sport springs on an IS-C would turn it into a rattle box.
With the f-sport springs is gonna be a little more stiffer then oem's of course. I live in Rancho Cucamonga, the road here is still pretty new so it isn't that bad BUT when I drive to Los Angeles.. I'm on high alert
. Bottom line is.. if you lowered your car on anything you're gonna lose some of your "Lexus' ride quality" but you also lose most of your wheel gap. Fsport is a mild drop, so you don't have to worry about scraping and camber wear
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I would think that the F-Sport Springs on the stock sport-suspension shocks would likely be not too bad, but the stock non-sport suspension shocks might be a bit soft for them.
I've never driven it with them, but I think I'd get the F-Sport shocks if I did, why do the job twice, I guess.
Jeff
Jeff
had a stock shock go out on fsport springs...my SA is trying to get the shock replaced under my extended Lexus warranty but it might be a no go since I put fsport springs on the car without the fsport shocks. They know it kills the oem shock faster.
That being said if she cant cover it then ive found a local guy selling a set of 4 springs/shocks oem so id just pull them all and then sell the fsport springs on the old shocks on here, the other 3 shocks she said seem to be in perfect working order. Hopefully its covered under warranty to save me all the additional work though.
