meagan street LP question???
just got them in and going to have them put on in am.... is there a good start setting??? i want lip right at tire.... and still have smooth ride, also have sage 30mm rca to put on at same time....
also can i still make adjustment to damper and hight after they are put in?? thanks
Account under Legal Action - Banned
Make sure you are super extremely careful with the ABS lines...and make sure they're secure. There's no rear mount for where the abs lines are in the rear so I used zip ties.
I also used some corkscrew gasket in between my body and the shock mount plate.
Tighten everything to spec. NO overtorque - it'll end up costing you. Make sure also to call megan directly if you have questions.
To adjust your coils, make sure to hand tighten the upper perches and then get it snug with the wrenches, but dont preload it. Then use the lower perch to adjust height.
There's no way to tell you how to tuck all your tire, you have to adjust that based on how your springs settle.
mike51O
Suspension and Brakes
08-01-11 07:29 AM
jdog0411
07-27-11 05:30 AM
