Best quality upper control arms
#48
trying to have camber correcting lower bushings in Feb, I am still waiting on factory samples.
Upper arms will be max negative camber arms with airbag clearance and fixed ball joint.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#49
I know this is old...but is there an update on this for custom knuckles, and less stress on the upper ball joint?
#50
Mike, when you're talking camber correcting with LCA bushings, you're saying that these will add + camber correct? I am in the market for more - camber for my front end, my RCAs, FUCAS, and OEM LCAs are maxed, as well as my steering knuckles, do you have anything that I can squeeze a few more degrees out of my set up? I am on the OEM FLCAs, maybe a different set of FLCAS or even bushings to add more - camber?
*Side note, my FUCAS are maxed at -5, but my steering knuckles correct +3 leaving me with -2 total in the front*
#51
Also, OP. Ive done option 1 and 2. I have S9 FUCAs along with T demand shorted steering knuckles. They have done me great and the geometry correction and clearance is generous, it is the most expensive option...but, however, has worked best for me.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1600x2000/img_20160725_205856_9f6758cb62f542f487bdae79df06632c14b7a305.jpg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1333/imgp5419_dd6345b06f97f608e4a063df56c086caf4a069da.jpg)
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1333/imgp5415_a59bc3cb5b0c9f8016722eee048142dedf126c74.jpg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/720x960/gs_hysteer_french_2_0837c11d8ef7786e2c93c5e4b13f4ff3961b92d7.jpg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/720x960/gs_hysteer_french_1_d390da0b28669928b9e8a7c475f9505355d40b3f.jpg)
__________________
#53
Mike
__________________
#54
i hadnt paid much attention to parts in a few years as the car was supposed to be leaving but now that its not i have been looking around again. i dont need them anymore but i see Mike's UCA are out and man they look amazing IMHO
http://shopfigs.com/v3/VIP-FUCA-GS-S...rice&order=ASC
tiguy99 (09-04-17)
