Old 01-07-15, 12:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Recent ball-joint change now squeaking?
Old 08-17-11, 10:20 PM
Arcadian
Arcadian's Avatar
Default Recent ball-joint change now squeaking?
I've got a 2000 GS, 100,000 miles. Lower ball-joints changed 10,000 miles ago (Beck Arnley). New Lexus shocks 2-weeks ago. Car is all stock, no lowering, no unusual tire wear. During shock change I asked the dealer to check everything including the LBJs and they said everything is OK. last couple days I notice a squeak on the left side when slowing and turning. When I bounce the left front fender it's quite loud and when I bounce the right fender, barely there. I'll try and attach a Blackberry video I made of the sound, there's not much to see as it was very dark in my garage. Any thoughts? Stabilizer bushing, upper strut mount. Please don't say LBJs. Thanks for your consideration.
link to audio http://dw3.convertfiles.com/files/06...10817-2156.wmv
Old 08-18-11, 03:21 AM
PHML
Master Thread Closer!!
PHML's Avatar
not lbj...but I'd check if the shocks and springs were installed properly, or could be just a bad shock.
Old 08-18-11, 08:58 AM
GS4_Fiend
GS4_Fiend's Avatar
Time for new shocks
Old 08-18-11, 11:24 AM
vwynn
vwynn's Avatar
my stock (not OE) shock/springs squeek a lot when going over speed bumps haha.
just change em if they annoy you a lot.
Old 08-20-11, 06:39 PM
oslouie
oslouie's Avatar
I'd be paranoid as hell if my car was squeaking on bumps/turning. I know on Honda's, that's the for sure sign that your ball joints are going to fail. But then again, your link to the sound clip doesn't work.
Old 08-21-11, 12:29 PM
try2fndmrk
try2fndmrk's Avatar
hmm.. somewhat similar to my problem where only the front squeaks when i do the "bounce" test(in PARK) on it but when i go over speed bumps(in DRIVE) its fine; iget "clunks" over potholes and uneven pavement.. annoying
Old 08-21-11, 08:30 PM
istundra
istundra's Avatar
I have same problem. I hope not springs/shocks since i replaced it with coil overs less then 10K miles ago.
I was worried about LBJ but my car is a 03 and has only 49K.
Old 08-22-11, 09:27 AM
vwynn
vwynn's Avatar
try greasing your sway bar bushing to see if that helps.
Old 08-30-11, 06:04 PM
Arcadian
Arcadian's Avatar
Default Feedback
Thanks for the input guys,
Of course after I book the car into the Lexus dealer, the squeak goes away!
I did buy a floor-jack and raised the wheel up and pushed, pulled, wrenched on the wheel. It's 100%rock-solid. I banged on the tire and rim from various angles, again, rock solid. Everything else seemed tight.
Believe it or not I think maybe weather-related. It's been kinda humid around here when it squeaked, but then dried up in the afternoon when it didn't.
I have new shocks and LBJs, but didn't change strut mounts.
I will try greasing the sway bar bushings.
THe funny thing is, I have an old beater Sunbird that squeaks and creaks when the weather turns cold - and now my Lex?! LOL
Old 09-20-11, 07:47 PM
Arcadian
Arcadian's Avatar
Default Update on front end squeak
OK, took my car in for new upper control arms today. So far, problem solved. Also, there's definitely a qualitative difference in the steering - less vibration in the steering wheel, quieter and smoother over bumps.
I went with Rock Auto instead of OEM, Lexus Canada wanted $400 per arm, Rock Auto $168, plus my friend at the Ford dealer charges $45 less per labour hour.
Come springtime, upper mounts TREs and strut bar.
Thanks for all the input, this is a great forum.
Old 09-23-11, 11:01 PM
Arcadian
Arcadian's Avatar
Default And it's back
UCAs installed, squeak gone, and now it's back worse than before. $1,000 wasted.
About ready to sell this thing.
Old 09-24-11, 07:52 PM
vwynn
vwynn's Avatar
so did you happen to check the sway bar bushings? to see if they need some grease?
UCLAJimmy
Suspension and Brakes
12-17-08 03:46 PM
tarnut77
01-29-08 08:28 PM
jracerlmn
08-31-05 05:48 PM
ScottURnot
09-02-04 06:25 AM
Lexiss_sc430
04-05-03 09:47 PM
Quick Reply: Recent ball-joint change now squeaking?
