UAS Airbag problem (clunk) sound and sway
yea i checked all the bolts i made 2 videos one with the axel and one i put in the trunk and video taped while the car was driving you will see the mount and the struts are bilstein sports... psi im riding a little high right now cause i have 20's but when its low still does the same thing
i hope u get this fixed but is this the same setup your trying to trade ATM?
https://www.clublexus.com/forums/2ge...coilovers.html
im not sure if its normal if the axle has that much play since i havent played around with it.
regarding the bags to see if its blown you can just remove the shock and remove the fitting. this way u can shine light in there to see if theres oil. when my shock blew i got vaporized air/oil mixture in my trunk when i deflated... but then again my fittings were located on the bottom.
i actually never removed airbags before. when i lift the car up does the bag have to be deflated? and i unscew the 3 bolts up top and 1 on the bottom which holds the strut. and then what i do next unbolt that big bolt in the middle or thats not a good idea lol cause i dont want that **** to shoot out or anything.. and the air from the airbag i know it says zero on my dakota digital guage so im guessing i can just unscrew and nothing happen
