19" wheels with L-tuned? Problems?
I am currently having L-tuned shocks and springs installed in my gs400. Will I have problems installing 19" wheels on the vehicle. If so what type of problems?
Thanks
Thanks
I don't see you having any problems with that setup. What size are you running (width of wheels). There are many members here running the l-Tune setup. It gives you about 1.2 inch drop. I have Teins with a 2.5 inch drop with 19's and I don't have any problems. Good Luck .
jcramair1,
You Should Have no problems. What offset do you have on the wheels....................... Im not sure if this is right or not but there might be a problem if you dont have the correct offset...might be rubbing..........GS4WILL will know for shore PM him
You will love the ride with the L-Tuned
I just got the Lsportline Suspension Installed yesterday Its a lil more firmer then the Ltuned...Ride is great .........Diff between the stock susp and Lsportline/Ltuned (w/bigger Wheels) is like Night and Day
