Need New Brakes, Advice Please
So I need new rotors and pads. I know the dealership will overcharge. Aftermarket will probably be cheaper and better quality. Any advice? Brands?
As for pads, ceramic is the way to go?
Rotors, slotted? Drilled? Both?
Best quality is usually OEM. The cheaper aftermarket parts aren't always the best. Of course there are aftermarket parts with better quality than OEM, but they are more expensive
If your not tracking it or anything, get some low dust pads off of Sewell and stick with OEM blank rotors (Sewell sells them too, or you can find comparables cheaper). Avoid drilled/slotted unless you really want them for show/track. My experiences with them are that slotted rotors eat pads faster and drilled rotors crack around the holes eventually. Either one, unless your tracking your car or something, your not really going to see any benefit.
Your replacing the rears only? For the rear, i don't think they have a "low dust" pad because the rears barely make any dust as it is. It's the front brakes that dust a lot unless your using the low dust brake pads. I had centric replacement rotors on my old car, had no issues with them at all...but the OEM rotors are a good price on Sewell too. Funny thing is, when you search through 2007 is250 the rotors are there. When you search through 2009 is250 like you did in the picture, no rotors. I wasn't aware there was a difference...hmm...maybe someone else can chime in here.
Also, i noticed your pic doesn't show the CL discount. Create an account on Sewell and during registration put in that your clublexus username where it asks if your on any forums. Go back to the item and you'll see a discounted price just for being a CL member. For those same pads you have in the picture, the price should be $46.84 with the CL discount. Save nearly $20
I just put Wagner Thermoquiet ceramic pads all the way around on mine and I really like them. Great stopping power and almost no dust. 2 weeks on these pads I don't have as much dust as 1 day with the stock pads. I've only got about 500 miles on them so far, so time will tell.
As to dust- you must've had the original high-dust pads... the low dust ones don't produce hardly any at all.... 6 months of using them looks better than 6 hours of using the high-dust ones.
To the OP- Centric OEM blanks are fine... as noted the sewell price on the OEM rotors isn't bad either with the CL discount... and yes it's only the fronts that have a low-dust version since the rears don't need one.
Your brake pads have nothing to do with your "stopping power"... any set of pads will stop the car in exactly the same distance as any other....anyone who tells you differently doesn't understand how brakes work. Different pads can do other things, but apart from service life, dust production, and the "feel" of the pad, they won't make any difference at all in normal driving performance.
Also, i noticed your pic doesn't show the CL discount. Create an account on Sewell and during registration put in that your clublexus username where it asks if your on any forums. Go back to the item and you'll see a discounted price just for being a CL member. For those same pads you have in the picture, the price should be $46.84 with the CL discount. Save nearly $20![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I'm looking to change the pads all around, dealership said I need new rotors as well for the rears.
Are these the low dust pads? Don't see any info if they're low dust or not
![](http://img.photobucket.com/albums/v708/bigdawgjz88/fb56e330.jpg)
They changed the pads to the low dust ones from the factory mid-2009 model year, so Sewell is not listing the old/new pads for 2009+ models.
You likely got an early 2009 though with the high dust pads.
Look at front pads for a 2008 and you'll see the choice of regular or low-dust listed though.
(dunno why they're not listing rotors, far as I know those parts didn't change at all from pre 09 models)
anyone here know about replace brake pads please help me : do i need buy the full kit ( shim kit , fitting kit ) when i replace new front pads or i just need new pads and still use my old shim + fitting kit on my caliper .
