Can someone label each Megan arm
Can someone tell which arm is what? I have an idea just want to be sure.
I borrowed this pic from here, I can take it down if it's a problem just let me know.
1.
2.
3.
1.
2.
3.
![](http://i452.photobucket.com/albums/qq249/EJ20/25836_630537854934_1319041_36434846_7270267_n.jpg)
Thank you sir! I'm looking to get negative camber for clearance, not trying to correct anything. With that said do i need both the camber arms? I installed the #1 arms already.
Also,one other thing. This gonna sound real stupid. will the #1 arm fit in the #3 arm spot and vice versa? I swear i put the #3 toe arm in the spot where the #1 camber arm supposed to go. It had the right part# on the box 6712, but it looks like the toe arm.
check these out....I'm gonna buy these instead of the Megan Toe arms. Figs products are of MUCh higher quality. Can be powder coated any color as well.http://shopfigs.com/v1/index.php?rou...&product_id=81
I'm thinking i put the toe arm into where the camber arm supposed to go. Intially it was a tad bit shorter like a 1/4 inch. I had to turn the arm to make it reach. I just need to figure out if i put the toe in the camber arm spot before i order another wrong part.
